Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
I got my car serviced on Friday. It's not running very well. I dont know whats happened. It's cutting out at idle and the revs aren't picking up by themselves when I first start the car. I've got to stab the accelorator to start it.
ANd I need to get my timing belt changed :) Doh!
Guest Boxhead
yeh thats basicaly whats happening to myn, but its got new spark plugs.. well newish, and it started great with the battery was new, but the new one is dying coz its not charging back up when i drive( which is alternators fault again!!! grrr...
ohwell.. erin - seriously check your battery indicator thing to tell you how charged it is.
Well mine only has the problem that you have to give it a bit of gas to start when cold...then the revs pick right up. Other than that all is sweet.
I've seen quite a few photos now that Justdave has taken of your car....i just assumed that he liked it. :D
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
