Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
nah ross, i just came up with the idea myself really, i mean i knew some people did it, and i figured it was better to have the pipe crossing under the car where its cooler rather than through the hot engine bay....
xu6 was hsv's supercharged and tweaked v6 commie, problem was when the ba falcon came out, the base 6cyl model out performed it
lol - nice progress on the engine development holden. ford are killin em in this department - quad cam v8's and dohc 6's.
yeah the x-over in the engine bay seems a bit silly. so yeah - is that a 90degree silicon bend or solid pipe?
ok the pipes cost me 150 bucks from memory
there were 2 45deg mandrel bends, 2 90 degree mandrel bends, and 1 180 degree mandrel bend. no silicone bends, silicon turbo pipe was costly (red joiners) but that was about it, only thing i have to do is support the pipes a little better cause when you hit it with full boost they move around a little bit
ross um
only other pic is www.ozemail.com.au/~jcornford/ic2.JPG
the pipes were done by ashmore exhaust, and then i just had to cut em to suit, it was a bit of a bitch tho, in the end i cobbled it together rather roughly but it works, theres a few things that could be done to tidy the whole thing up if i get the time, which i incidently have now, i just need to get the effort :D
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
