Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
i went thru that shit as well. keep seeing my friends violently killing me in my dreams. i thought i was going crazy. a change in lifestyle and some wicked sleeping pills sorted it out. hope things get better sooner rather than later lovely. ;)
i know what caused the alien one - that movie "Signs" ..... aliens were throwing gas bombs in the building i was in.
As for the crash ones .... no i cant think of anything triggering them - its just they are so real and i think thats what upsets me the most. I used to wake up only once thru a night now i wakeup about 5 times and find it hard to get back to sleep.
ive just started on exercise etc
Just before u came back Paul - actually i think it was the night before u got back.
I dont know - mine could be ex related too .... a mutual friend my ex has recently used to play a bit of a mind game with me .... long story - but i dont talk to him anymore because of it. If Andrew wants me to hate him he's going the right way about it - but i think this is the last of it all!
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
    • Yeah thats the plan now. 🤞
