Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
i went thru that shit as well. keep seeing my friends violently killing me in my dreams. i thought i was going crazy. a change in lifestyle and some wicked sleeping pills sorted it out. hope things get better sooner rather than later lovely. ;)
i know what caused the alien one - that movie "Signs" ..... aliens were throwing gas bombs in the building i was in.
As for the crash ones .... no i cant think of anything triggering them - its just they are so real and i think thats what upsets me the most. I used to wake up only once thru a night now i wakeup about 5 times and find it hard to get back to sleep.
ive just started on exercise etc
Just before u came back Paul - actually i think it was the night before u got back.
I dont know - mine could be ex related too .... a mutual friend my ex has recently used to play a bit of a mind game with me .... long story - but i dont talk to him anymore because of it. If Andrew wants me to hate him he's going the right way about it - but i think this is the last of it all!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
