the n1 skyline is sort of a mystery car the engine is not the only thing that makes it special
r34 gtr n1(v spec11) has: ano a/c,no sound deadening, no stereo,
cfiber mirrors & bonnet. larger n1 turbos no rear wiper & to answer your question the engine is named rb26dett blueprint. try a search engine for the specs. or check gtr34 NUR which shares the same engine
N1 engines use roller bearing metal turbochargers instead of the standard ceramic turbochargers. Other differences are reinforced engine block, reinforced piston and conrods, different piston rings, different oil pump, different water pump, different exhaust manifold and different intercooler. (the list goes on!) I read somewhere that the engine output was around 330kW's.
The N1 engines are hand made at the Nissan's racing engine division (NISSAN KOHKI).
Hope that help :P
  • 3 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
