Nissan Skyline R32 (4 Door) GTST
Black
1990
manual
sunroof
Exhaust system
Coilovers
HKS pod filter
82500Kms
GTR bonnet
GTR wheels Rears Front ones are off at the moment
Asking price 12500 With 6 months registration and safety certificate Price negotiatable of course to interested buyers
Contact me on 0431161238
Cheers
Edited by MFC05
https://www.sau.com.au/forums/topic/109732-r32-4-door-m-spec-black/
Very interested. Just what im after.
Any interior and engine pictures. Any further details of the car.
I have friends and family that can have a look at the car and i would like to get a Inspection on the vehicle.
Has the timing belt been replaced yet?
Any further information could you please PM me.
If car is sold are you still importing the R32 sedan and something like a 1992 model would be what im after.
Cheers,
Brenton
Cheers,
Brenton
PM Sent
BUMP
  • 2 months later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
