/\/orthside - Dinner - Tuesday 4th March
Duncan suggests a place called Orchid Thai.
duncan says....
Next Tue, 4-March.
Orchid Thai,
296 Great North Rd,
Abbotsford.
9713 5248
Need numbers by Fri so I can book.
To get there, go down Centenial drive from Chatswood, past Hunters Hill and over Gladesville bridge. Turn Right at lights at end of bridge, follow this road to Lyon's Road. Turn Right onto Lyons Rd, follow for about 1km. Turn Right onto Hampden Rd, follow to end. Restaurant is just to the left on Great North Rd.
https://www.sau.com.au/forums/topic/10984-orthside-dinner-tuesday-4th-march/
OK, currently booking for 8 ppl.
Pretty poor turn out, is it too far south for you guys?
Helen, we don't talk about handbags and shoes, we plot on how to own team westside back....
Current ppl:
Dundan
Kel
BY BY
Merli
SilverArrows
+ g/f
Bigvis
Kabab?
