help need to find someone who has contacts with nengun or someone who has an accound with someone who can get me a turbo kit from japan or australia for my rx8, ive been looking at modyourcars website and they have the kit for $7500 recently bumped up from $5900, but nengun has the same kit for 4500 delivered, please if anyone can help be much appreciated, dont feel like handing over 4500 to someone in japan not knowing if i will get my kit.
https://www.sau.com.au/forums/topic/109900-need-help/
I recommend using Perfect Run
Website is www.perfectrun.com.au
I've bought plenty of gear from him, and so have people I know. Never been a problem, not even once. However, you might have to pay some customs tax on it when it turns up. But you'll still save heaps.
He has the greddy turbo kit for around AU$4300 + shipping:
http://www.perfectrun.com.au/performance%2...ddyturbokit.htm
Checky-checky check it out!
https://www.sau.com.au/forums/topic/109900-need-help/#findComment-2028100
Why not check out some Ausie kits going around, you might pay a little more, but the quality of the kits are very good and you have the added bonus of local warranty etc.
Example this is taken from Rotor Master (I know its a supercharger, but its still good).
http://www.rotormaster.com.au/subPage.asp?cid=50
Specifications:
> Coolest charge air temperatures for maximum power and engine reliability
> Highly efficient C2 ProCharger
> Rigid 6061 T-6 CNC machined brackets
> Patented self-contained technology eliminates need to punch a hole in your oil pan
> Patented friction reduction drive for least parasitic load and greatest durability
> Helixed 7071 T-6 billet impeller
> Highly effective and high flowing DNA Motorsport air-to-air intercooler system for easy installation
> PowerMod - ProSequential advanced engine management system
> Complete bolt-on system
> No bodywork cutting required
> OEM fit and finish
> Factory smooth driveability for daily use
Priced at AUS $11,900 in boxed form (ready to install) the SuperCharger kit is modest value with a 200+ kW rear wheel result with a standard exhaust system ensuring noise maintained at an appropriate level.
There are two turbo kits available on this website:
http://www.turbo-kits.com/rx-8_turbo_kits.html
Plus other accesories available if going the turbo route.
I was reading about another one recently in a magazine, i'm pretty sure it was Zoom, it was also an Australian kit. I thought it was ASE but I checked their website and it wasn't them?
https://www.sau.com.au/forums/topic/109900-need-help/#findComment-2028446
Specifications:
> OEM fit and finish
do you think 12k is worth 200rwkw, i dont think so
https://www.sau.com.au/forums/topic/109900-need-help/#findComment-2028597
what you looked at was for a supercharger kit, they are known to be expensive.
look at the turbo kit
theres one for $4K suppose to be 260rwhp
that power figure is only on 5.6psi, i spoke to c and v the other day and they gaurentee it will make much better power at 10psi daily driver, over 350, i dont care im gonna risk it, if anything i would be a crayy tyre fryer
https://www.sau.com.au/forums/topic/109900-need-help/#findComment-2028929
i second this guy. perfect run have prices as good if not better then nengun and greenline. there service is better then both, i have dealt with all 3... and the best part of it is..... THEY HAVE A SHOP IN SYDNEY !
so give them a visit and pay in person if you wish :(
i would get one but they dont speak english and the only way to contact them is by email, bit sus to me
wrong, see what i said above ! go see them in person if your real worried..
https://www.sau.com.au/forums/topic/109900-need-help/#findComment-2030898
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
