Hiya,
driving halfway and the engine just died....the oil and the battry light went on...and I got to restart the car again...just stops like that, no stall nothing, I notice the power steering lock is back on....It's the 3rd time for the past two weeks, all happened as I am braking...once while stopping straight...twice while stopping to turn...
I'm using an automaster alarm, my best guess so far is that the alarm unit is faulty and cuts the fuel some time after the car started...however according to the manual, if that happens, the car will get locked; which it does not....need help, this is really dangerous, can't imagine what would happened iof the car just switch off midway driving the freeway
bckground detail....
about two weeks ago I installed a PFC, Greddy boost controler..however the boost controler was faulty so I removed it ..I'm now running 5 pound of boost without any boost controler...other mods, only a BOV HKS filter and CAI box...dun think these causes what's happening anyways.....
https://www.sau.com.au/forums/topic/109963-r34-gtt-help/
My suggestion as with all "sudden" enginge faults is to double check all the wiring to the ECU - make sure it's all connected properly and tucked away neatly.
Mate has the same problem whenever someone accidently kicks the ECU area as his wiring is not done in the best manner.
https://www.sau.com.au/forums/topic/109963-r34-gtt-help/#findComment-2026486
dun think it's bov stall...if it's bov, will feel the stalling like vibration thing....this one jsut turn off...I didn't even know that the engine is off..
yah I'll check with the alarm and the ECU..thanks for advice
https://www.sau.com.au/forums/topic/109963-r34-gtt-help/#findComment-2028316
mmm i had this problem while drivin my moms ford falcon AU but apparntly in only happens when i drive it !! the car is a standard 99 falcon. i didnt think it was that bad when it happend a few times in low sppeds just b4 red lights or just as im pullin outa the driveway or pullin into one but when it happend while i was turnin from a 70ish zone :down: to a shopin centers car parck and a car was behind me .. just on the 90 degree turn and ir dyed and stoped turnin i was about to go into a tree and a car bihind me had to kill thier brake to avoide me and u can emagine the other cars behind that.. anyhow i took the car to many diffrant mechs and they all sed somethin diffrent but none actuly solved it as far as i know im not drivin that car no more and if what mom sez is true then u should just eaze up on the brakes i guess and ull be fine. id love to know what the problem is
https://www.sau.com.au/forums/topic/109963-r34-gtt-help/#findComment-2028520
I't really rare I don't know what to with to the mechanics...
now it's back to normal...
yeah the engine just died when abt to break...so i've got one last step of break...
I'll see what they go to say...will keep posted
https://www.sau.com.au/forums/topic/109963-r34-gtt-help/#findComment-2046089
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
