how bout a thread for pot holes i hit one on parramatta road before one of the homebush turnoffs i thought my mag bend .lucky for my strong deep dish starcrop mags.I hate sydney roads should be able to sue council of whatever area for new suspension and new wheels! anybody else? :)
i gunned it just before this f**ken black hole in the left lane (same spot as u im assuming)... hit it so hard that I as well thought my rims just snapped in half. And I got wheel alignment the day before f*k! Luckily no damange
https://www.sau.com.au/forums/topic/109966-potholes/#findComment-2026479
THAT STUPID ROAD GOING THROUGHT THE ARMY BARRICKS!
omg.. and just over the bridge.. shit.. that f's my car up like a mofo
I got a friend living on that street...
And they actually fixed that road once... Then they had to rip it up coz of the new houses contructions.
The worst is down Anzac pde, between the franklins shopping and the Maroubra rd cross. Going towards lapar.
It was once very nice. Damm all these constructions around the place.
https://www.sau.com.au/forums/topic/109966-potholes/#findComment-2026670
I just got back from having the front windscreen replaced in my work hiace van. Had a couple of tiny tiny tiny stone chips at either end of the window and then afew months back the council had to re-tar a 1ft wide section of a road I go along on the way to my work depot each morning. the section that had the new tar was about 2 inches higher than the road and their was no choice but to hit it doing about 60km/h. So 2 of the stone chips resulted in 2x 30cm cracks in the screen :D
Since then the council came back and scraped it back so it's level with the rest of the road, idiots!
Luckily it was a free insurance job.
https://www.sau.com.au/forums/topic/109966-potholes/#findComment-2027530
i dont know if any of u guys driven on pittwater road on the northern beaches, this long stretch of road is a piece of crap filled with potholes, and uneven patches of repairs.
majority of it is not even tarmac! its slabs of concrete sealed together with tar, so if you got some stiff suspension your be bouncing in your seat for a few km's. i drive the backstreets just to avoid that crappy road
https://www.sau.com.au/forums/topic/109966-potholes/#findComment-2027557
My favourite is still driving towards Campsie on Parramatta Road (the one right next to the clock tower) - that place is horrendous for pot holes! But after seeing my ex for 2 years, kinda got used to the bumps and learnt how to navigate through it...
Yes, Pittwater road is an absolute bish as well... always sounds like you've got a flat spot on your tyres (all 4 of em :D)
Another one that's really bad is coming into Rockdale from the city, not really pot holes but just a series of ridges on the little bridge, makes the car jump all over the place.
Suspension = TEIN HA Coilovers with damper on setting 16 :D
https://www.sau.com.au/forums/topic/109966-potholes/#findComment-2027576
oh oh fitzgerald is so much more worse..
i hate that road i always try and avoid it..
https://www.sau.com.au/forums/topic/109966-potholes/#findComment-2032115
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
