Hi
I was wondering if anyone could answer my question about how to become a trader on the website and what pricing options are available. I have emailed [email protected] and pmd two moderators with no avail and further the link http://www.skylinesaustralia.com/forums/trader_info.php is dead.
Can anyone please help me?
Thanks
Marcel
https://www.sau.com.au/forums/topic/109977-being-a-trader/
  • Replies 54
i have emailed both of them twice now
my patience is running extremely thin
and also at least of them is online rite now
You've given them just over three days - of which two of them are a weekend. I hope you do realise that they do have lives too and not attached to SAU 24/7.
Nick (Blitz) is the one to get hold of for trader status, you've let him know and I suggest you just wait and not be so impatient. :P
https://www.sau.com.au/forums/topic/109977-being-a-trader/#findComment-2034537
I generally dont read my PM's for 1-2 weeks at time.
Even though im logged on everyday.
Christian just doesnt read PM's
And Blitz runs the busiest section on the forum
They might have had 15 enquiries this week ontop of yours.
Stuff can take a while to get through.
https://www.sau.com.au/forums/topic/109977-being-a-trader/#findComment-2034807
hey mate
ill be selling a variety of parts, but first up will be a wheel group buy (which was deleted from the parts section in 5 minutes after posting).
and still no reply from moderators!
Email me please, nick at skylinesaustralia.com
I will get back to you asap
https://www.sau.com.au/forums/topic/109977-being-a-trader/#findComment-2096689
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
