Hi,
I'm trying to replace my stock R33 2 din CD deck with a new Panasonic CD player.However, when I took the old player out, I notice that the input cables are different to my new decks. The audio plugs (from the car) are blocky little square things, and they dont plug straight into my new deck!!
Has anyone experienced this?Do I need to modify the line outs...?
Help!
https://www.sau.com.au/forums/topic/11002-installing-aftermarket-cd-deck/
You need either a multimeter or continuity indicator & pen and paper - this is essential.
8 of the wires in the cars loom are for speakers. don't worry about them for now.
From the factory loom, using your meter:
you'll need to ID a constant 12v source - connect to (RED wire) on your deck
and a 12v ignition switched source (ie 12v only when key turned) connect to (YELLOW wire) ( usually) on your deck
for ground, you can use the wire in the loom, or attach it to the vehicles chassis. If you're planning on adding amps at any stage...ground it to the chassis & ground your amp(s) at the same point (star earthing). this helps keep unwanted noise out. connect (BLACK wire) on your deck.
Suss the power antenna cable & connect to the app. cable in your deck's loom.
So now you've written down what cables go where. Disconnect the (-) terminal from the battery and solder or join these wires. Reconnect the battery, you should have vital signs on the deck.
Then you'll have to work out the speaker wiring. this is best achieved with a AA or similar battery.
They're generally grouped together & 4 will be black (with individual coloured traces) connect a black wire to the batt(-) and its suspected partner to the (+). if you hear a pop, congrats you've found a speaker. do this for the other 3 speakers, record what goes where & solder or join.
Yes, you can use bullet or similar connections, but if you can get hold of a soldering iron you'll never have grief with your installation. It's enough of a pain installing it the first time !!
Hope this helps.
I posted the stereo wiring diagram for an R33 a month or two ago when i did my car..you just do a cut and connect to the right wires.
Here is the post. Enjoy!
http://www.skylinesaustralia.com/forums/sh...ighlight=wiring
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
