well my theory is i was makin 270rwhp before at 1bar but that turbos efficiency range would be 18-22psi. so while making decent power it wasnt working at the optimum rate
with a smaller exhaust housing the new turbos efficiency rating should be around 14-16psi (where i will run it) and so will work better and hopefully rpoduce similar power figures to what i had before
https://www.sau.com.au/forums/topic/11042-turbo-rebuilding/#findComment-182075
UPDATE: Last night with the help of macka and shannon the turbo came off. macka took some pictures if he could post em thatd be good...
anyway it turns out the exhaust housing was in fact a .63 already but with a big mofo wheel. this setup was spooling at 4500rpm with power over 5000rpm...
i am going to try either a similar sized but different trim wheel, or get a new .63 housing which hasnt been machined as much and put a smaller wheel inside it. the turbo goes into United today so will let you know how it all goes and what option we choose
https://www.sau.com.au/forums/topic/11042-turbo-rebuilding/#findComment-183620
Im glad u mentioned us that time Adam!
It looks like we will put a smaller ex wheel on with a shallower trim on a new .63 housing.
He has a GT25 compressor and GT40 Exhaust wheel :)
Yeah i agree you should make similar power at 1bar with a shallower trim wheel in it.
The comp wheel needs to go up :P
Ok ill resize some photos tonight and post just cause its you Ketz
https://www.sau.com.au/forums/topic/11042-turbo-rebuilding/#findComment-183831
me n mack have pretty much figured out what size wheel we want to put in the new .63 housing... but were gunah chat to steve and see if hes got any thoughts, hes the expert after all
mack i remeasured the comp wheel (more accurate) someone from engineering did it with these vernier extensions so it could go into the inlet pipe
its 58mm and the exhaust is roughly the same
https://www.sau.com.au/forums/topic/11042-turbo-rebuilding/#findComment-184436
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
