well my theory is i was makin 270rwhp before at 1bar but that turbos efficiency range would be 18-22psi. so while making decent power it wasnt working at the optimum rate
with a smaller exhaust housing the new turbos efficiency rating should be around 14-16psi (where i will run it) and so will work better and hopefully rpoduce similar power figures to what i had before
https://www.sau.com.au/forums/topic/11042-turbo-rebuilding/#findComment-182075
UPDATE: Last night with the help of macka and shannon the turbo came off. macka took some pictures if he could post em thatd be good...
anyway it turns out the exhaust housing was in fact a .63 already but with a big mofo wheel. this setup was spooling at 4500rpm with power over 5000rpm...
i am going to try either a similar sized but different trim wheel, or get a new .63 housing which hasnt been machined as much and put a smaller wheel inside it. the turbo goes into United today so will let you know how it all goes and what option we choose
https://www.sau.com.au/forums/topic/11042-turbo-rebuilding/#findComment-183620
Im glad u mentioned us that time Adam!
It looks like we will put a smaller ex wheel on with a shallower trim on a new .63 housing.
He has a GT25 compressor and GT40 Exhaust wheel :)
Yeah i agree you should make similar power at 1bar with a shallower trim wheel in it.
The comp wheel needs to go up :P
Ok ill resize some photos tonight and post just cause its you Ketz
https://www.sau.com.au/forums/topic/11042-turbo-rebuilding/#findComment-183831
me n mack have pretty much figured out what size wheel we want to put in the new .63 housing... but were gunah chat to steve and see if hes got any thoughts, hes the expert after all
mack i remeasured the comp wheel (more accurate) someone from engineering did it with these vernier extensions so it could go into the inlet pipe
its 58mm and the exhaust is roughly the same
https://www.sau.com.au/forums/topic/11042-turbo-rebuilding/#findComment-184436
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
