A Minh Endorsed TeamWestside cruise meetup this Saturday
  • Replies 135
thanks man! It does go hard for a non turbo! sorry about the off topic crap I just got the car and im curios. See u all at cruise I hope u all make it and I hope I do too.
good nite and dont club toooooo hard 2moro!
I wanna be there man - Good to hear us snobs are included.... Gotta take care of one smallish problem tho - called double booked with old friend from school - maybe I can convince her to come cruzing too ??
Originally posted by Majanal
What time are you planning to leave Homebush... I doubt I can be there before 8:30 due to work. I might be as late as 9 though.
well i say we give till 9 just so we can give everyone a chance to get there, i say more cars the merrier
Is she hot?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
