Hey Guys,
Heading out to my first track day (no speed limit) at Wakefield next tuesday? Is anyone else on here coming along? I can't freaking wait to see what my stockish skyline can do. I have
R33 Series 1 Skyline with 17 Work Rims
Bridgestone 235 G3's on the front and Bridgestone (?)255's on the rear
JID coil-overs with Japanese uber hard springs
I'm really interested to see how these super hard jap springs perform on the track (perhaps I should keep of the ripples : )
I would consider myself a responsible novice and would love any help or advise from fellow lines heading out there as well.
4 sleeps to go!!!!!!!
Russ is a god, he knows all the lines.
http://www.hgeconsulting.com.au/[email protected]
But seriously, if you use 2nd ger on any corners then your corner speed is a little down on what it could be...thats about the best advice i can give
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
