Ah ok, yeah I see exactly what you mean. So this means that an engine has to flow exactly X amount of air to make X amount of horsepower, so therefore a turbo that flows 38LBS/Min = approximately the amount of air required to create 380HP of power?
The way Garrett and most other turbo manufacturers rate there turbos is as follows.
They run up the compressor until the pressure ratio is exactly 2.0, that is exactly 14.7 psi boost. They then steadily increase the airflow up past the efficiency peak until the adiabatic efficiency drops back to 60%.
You can do it yourself by eyeballing a flow map. Draw a horizontal line at 2.0 pressure ratio, and note where it crosses the 60% island on the map in the choke region (to the right). Then drop a vertical line down to indicate flow.
Engine power is assumed to be one Hp for each 1.5 CFM at that operating condition.
It is just one standardised operating point on the whole flow map to very roughly compare one compressors flow capacity to another compressors flow capacity. An actual real engine may operate a long way from both 14.7 psi boost, and the 60% efficiency point on the map. But it is still a pretty good average operating point to choose.
The exhaust turbine flow, or back pressure, does not come into this at all, but is also extremely important for the engine.
Actually you will find that most compressor maps are graduated in pressure ratio vs the mass of the air pumped in lbs/min . The problem with measuring airflow in cfm is that it gives no clue as to the air temperature and therefore density .
Because of the mores law factor the maximum choke flow is usually considered to be what the compressor can dish out and horsepower worked from ~ 10-11 Hp per pound of air .
This really is a nonsensical way to rate a turbochargers power or I should say mass airflow potential . It makes the huge assumption that the turbine can get the compressor/housing combination to perform as it did on the test flow rig . All too often it can't so the result is not an accurate real world achievable one .
Cheers A .
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
