hey y'all
i'm trying to find this link to a step-by-step process of cutting the lip off the GT-T bonnet.
I'm pretty sure it was a .jp address, but not 100% certain. I can't for the life of me find the link! i think it was in japanese but it had pictures as well, like step-by-step.
Tried searching here, skylinesdownunder.com - hongkong skyline club - no luck
I would have had it in my favourites before my computer died and was probably in a thread here before the big crash -
anyone know of the page i'm talking about? or better yet have the link?
cheers,
chinny
https://www.sau.com.au/forums/topic/110956-cut-the-lip-on-r34-gt-t-bonnet/
mate, if you could that would be great.
but if anyone else happens to come across it in the mean time........ >_<
i'm glad someone knows what i'm talking about! always nice to know that i'm not losing my mind
  • 3 weeks later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
