mine smells like vanilla, fuel and sex.
ITS VANILLA!!!!!! when my mate got his it was strong smell... then when i got mine it was a strong smell... its a yello tree that was hanging from the mirror.... with the word VANILLA written on it....
but now the smell isnt as strong but its still linguring there... might have to buy another one.
PS can buy them from any auto store
