Has anyone got an updated link to download the Nissan FAST program? one that works, all the old ones theough the site is a bad link. Or is there some1 that can do a check for me? Greatly appreciate it :)
:D:thumbsup:
Edited by scheris
https://www.sau.com.au/forums/topic/111137-nissan-fast/
cheers dude, black colour code and model spec,
GGKBRTFR33VDA----A
time to find out what that means
more and more searching... sorted
sweet
so that says its a 3325t rwd and thats pretty much it, cool
so it matches what i've been told, 97 model, black, awsome the body is in good nick, so just wait on the inspection tomorow and see whats what
then buy me a line and enjoy.... thats gona be one helova drive home
hehehe
then a few days off to swap some bits and put in my stereo, complete the exhuast and install the alarm
Edited by scheris
https://www.sau.com.au/forums/topic/111137-nissan-fast/#findComment-2048837
Hi sorry to be a pain but is it possible to get another vin check? The last car didnt too well in inspection and we've decided to go with a second choice. I'd greatly appreciate it :D
The vin is: 6U9000ECR33106664
Thanks heaps!
:mellow::)
https://www.sau.com.au/forums/topic/111137-nissan-fast/#findComment-2051562
funkymonkey
not to push you or expect you to go out of your way or anything dude,
i appreciate you doing it the first time
mechanical inspection comes out great on this car but the scrapes and scratches and a little hail damage.... argh... so long to find lol ow my other car is out of rego and I have to buy something .... spuen
well it sounds worse than it is, even with ugly bench of a wing on it, still awsome car and not to shity pricing
https://www.sau.com.au/forums/topic/111137-nissan-fast/#findComment-2053162
  • 3 months later...
Built: 02/1997
Original colour: KH3 (ext) K (int)
Model Spec: GGKBRTFR33VDA----A
Engine: RB25DET
Model: R33 GTS25t Type M
Trans: 5sp Manual
Drivetrain: RWD HICAS
Hey Funky,
I've been looking around for a couple of hours now for a skyline model codes break down for r33's and have come up with diddley squat so far. Mate, can you look up a vin for me please on fast?
6u9000ecr33146691 or break down the model number ggkbrtfr33vzaaaydm. I'm looking to purchase this car tomorrow and it would help me greatly if you could check it out for me. It has 40th anniversary badges on the c pillars but no active lsd and after market seats so i cant check for seat badges. Sounds abit fishy to me. Thanks mate.
https://www.sau.com.au/forums/topic/111137-nissan-fast/#findComment-2299869
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
