R34 Models
aridyne
 Share
Hi,
I am keen on getting a R34 either GT-X or GT-V. My concern is that I have been told that the GT-X FOUR is not avialable to import due to the power to weight ratio as it is a 4WD rather then RWD. I thought with a 4WD being a safer option that it would be. Can anyone please let me know what R34 Models can be imported into Australia.
I know there is a few models:
GT (2DR and 4DR) RWD
GT-T (2DR and 4DR) RWD
GT-X (2DR and 4DR) RWD
GT-X FOUR (2DR and 4DR) 4WD
GT-V (2DR and 4DR) RWD
GT-R (2DR Only) 4WD
Are these correct and can any of these be imported?
Thanks heaps for any assistance.
Cheers
Aridyne
Yeah I am really keen on a 4 Door GT-X or GT-V, but really the GT-X FOUR would be ideal as its 4WD. I don't understand why they wouldn't allow the GT-X Four in as its the same power and a GT-V or GT. It has better options as far as I can see and is 4WD.
its all about power to weight ratio. with the 4wd system is probably too heavy to import.
the GT-V is exactly the same as the turbo model with bigger brakes etc but is just naturally aspirated....
Paraphrased from RCVS:
- Only vehicles with the features listed below satisfy this entry: RB25DE, RB25DET, RB26DETT
- The RB20DE cannot be imported as it fails the performance requirement.
Ergo, if the variant has one of the approved engines you can import it.
The GT-X Four is a RB25DE same engine as GT and GT-V and GT-X. So its not an engine thing for sure..
Someone please say yes to the GT-X FOUR.. I need a family car for the missues that I can play with when not driving my R33. :O
http://rvcs-prodweb.dot.gov.au/sevs/030-00.htm
That's where I got it from.
Clarify it with a RAWS if you want a definitive answer.
//edit: I do believe that all of the non-turbo four door R34s are ineligible as they fail the power/weight criteria.. which is why you can import something like a GT-V (as they are a two door)
Where is the power to weight criteria? I can not seem to find this. I have emailed DOT so I expect an answer soon me hopes.. :drag:
In that link I posted it clearly assesses the four criteria necessary for a car to be eligible for importation under SEVS.
As I said, contact a RAWS. They will give you a definitive answer. They're the ones who will end up doing the paperwork for it anyway.
I contacted RAWS whom just showed me the same form that you guys pointed me to so. They just said all R34's are ok as long as it doesn't have the RB20DE, and the form states the 25GT-X Four and 25GT Four are okay. The power to weight criteria also seems to be met with the RB25DE being 105kw/tonne
Now its a matter of getting one and stuff like insurance I think. Being that it's a rare style of the R34 will compliance be different as well?
Hope they don't tell my customer with his NA r34 sedan which is currently getting complied then :D
Not sure on the AWD models - but if it's not specifically listed on the RAWS website as being ineligible, then you can assume it's eligible. Either way, you might want to seek clarification from DoTaRS.
Just double checked - the AWD variants are listed in the original application, so yes they are eligible.
Edited by vrfour
Hope they don't tell my customer with his NA r34 sedan which is currently getting complied then :(
Haha that's why I said I think.. lol this rabbit is funny! :D
 Share
    • Go to SP mufflers and get the muffler of size you want and make a nice mid muffler. It's about that simple! I have 2x 3.5 Magnaflow straight through Mufflers and while it's pretty loud with the Varex open, it's quiet enough with the Varex closed. You can also buy off the shelf Magnaflow straight through mufflers as well. You also have a turbo to quiet the car down too. Don't overthink it. Buy my extra Magnaflow muffler sitting on a shelf doing nothing (buy it new, ignore this part)
    • Centre-offset muffler under the floor, same as stock. Just....3.5". The change from straight pipe there to centre-offset will mean that you need to remake some of the pipe (add a bend or two).
    • Hey guys. So my R34 GTT has a custom 3.5” exhaust (done by previous owner) with a high flowing cat, and then just a Varex cannon muffler on the back. The car does drone alot and is really loud even on highway driving just cruising, as you can imagine due to the Varex muffler basically being a straight through with the valve open. As much as i love a loud RB, it can be a bit much with no other muffling in line and just driving casually. I wanted to lower the volume output on the exhaust a bit, as well as remove the drone (probably a way to do both at once), and was going to do it all myself as I am a fabricator and have done exhaust work in the past, so the fab work isnt my issue, im just not sure on the right product or type of product to use to get the job done, and i doubt an exhaust shop would be wanting to help me as they wont be making any money from helping me, unless they supplied the product? Anyway any help or guidance in best way to approach this would be awesome   Thanks in advance
    • Meh, whilst the Honda is a "really" good car and has potential if you want to drop coin on, it was uninspiring for me to look at, but, it did serve its purpose and is now in the boys hands, his happy, his girl is happy, as she wasn't to keen on the noisy old Patrol, and most importantly, the Minister for War and Finances is extremely happy that her "little baby boy" (6'2 nugget who is currently training to be a copper, which will make 3 coppers in the immediate "circle of trust") has a well sorted reliable car that doesn't guzzle diesel Me, I'm more than happy with the NC MX5 that I replaced it with, it's a fun little car that I like looking at, like driving, and yes..... I do like the fact that the maintenance and modifications that I have done/will do are plentiful and relatively cheap, well........ while staying naturally aspirated slow that is, and that's all I really need for a fun little daily, I can rev the 5hit out of it rowing through the gears and never really break the speed limit  In saying that wicked word, "modifications", I've already ordered something for some noise and an additional "3 ish" horse powers, or whatever it gives, in the form of a header, and, a new set of "cheapo" BC coilovers that are already sitting in the shed waiting to get put in, I had the same BC's in my old NB and found they were fine for the street, hwy, and the occasional track days I did in it, they have 6kg front and 4kg rear springs which is about 10% stiffer than the stock springs which I found worked well for their price  I've also already been in touch with MX5 Mania in Dural, so once the header is on it will get a ECUTek RaceROM tune there (I cannot rev match for 5hit, and I loved the RaceROM rev match and FFS in my old 86 "RIP") In other, maintenance news, I put some new sparkler plugs in it, and have a new set of DBA Street series pads to put in over the next day or so, I'm running the DBA street series in the SS and Honda and really like them, they work great and are not dusty at all I've also booked in a few days leave over this weekend to give me 4 days weekend do some paint correction and give the leather seats some conditioning and interior some Bissell and steam cleaning OCD lovin', the carpet and interior looks clean, but from my experience with the Bissell IRT carpet, and the steam cleaner IRT trim, looks can be deceiving I've also found that finding a detachable hard top is proving problematic, the main reason why I didn't like the NC initially was the power retractable hard top that I seen them with gave the roof line a weird look, the detachable roof though looks good, and is a same shape as a NA/NB hard top, similar, but unfortunately not the same as it has different fixture point on the front, so fitting a easy to get NA/NB detachable hard top is no bueno New Old cars are fun, cleaning, hunting and playing around brings much joy How are your beasties going? Do you still have the Skyline with the LS???, or Barra??? that you were playing with
