I have 2 questions and I will start a seperate thread for the other one which will probably get a one sided response... anyway.. for this topic..
Closed deck and so forth are frequently spoken about in Subawho circles in regards to the engine.
apparently the RS turbo Liberty's were the only ones with a closed deck and all the WRX ej20's after that have been semi closed deck.. and the NA ej engines are all open deck.
so that's all lovely, but what is it in reference to?
why is closed deck better?
is this "DECK" type something in all engines or just the boxer motors?
if in all engines, what are the RB range of engines?
cheers..
I think hes referring to the combustion chamber in the head the recessed part where the in/out valves are and the spark plug.
Im guessing one type is where its recessed like in rbs..and another type is where maybe its flush or closer to the actual bore/piston?
That would be my interpretation.
"deck" refers to the block
open deck blocks have the cylinder liner un suported by the block up top.
honda and subaru, (except rs-turbo)
semi closed is where the liner is partialy suported up the top. ie youve got the bore with suport bits stoping the liner moving around.
ie:sr20,some hondas.
(open and semi open deck are mostly alloy block engines)
closed deck is where the only gap around the liner is small holes for the water galleries. ie:pretty much all iron block motors.
NIB,
Block guard kits (such as the Nuformz) for Hondas are not as good as you would think... People simply look at it and assume its stronger without considering what they really do...
If OS can build an open deck engine that revs to 13k and makes over 1200hp without a problem then maybe there's something in that. maybe..
Just some info I had lying around. Can't find CA.
R = 6 cylinder, closed deck.
B = Gasoline application using cast iron/nickle based block.
S = 4 cylinder, closed deck.
R= Gasoline application using sand-cast alloy based block.
K = 4 cylinder, closed deck.
A = Gaslone application using sand-cast iron based block.
Q = 4 cylinder, open deck.
R = Gaslone applcation using die-cast alloy based block.
Deck isnt Subaru slang... it simply refers to the top flat surface of the block that mates to the head gasket and cylinder head...
T04gtr,
If the open deck is inferior, then why did OS Giken choose it for their all-conquering RB30?
That's a spacer, the deck (top of the block) is still "closed" where the liner is inserted.
:D cheers :D
T04gtr,
because the "open" part is only very short and made of high quality ductile iron so it doesnt flex silly,not run of the muck cast iron.
besides its abit harder to make a fancy sleeve spacer on a 20k bottom end.lol.
who knows. perhaps they know its bolted/pressed onto a rigid iron block
(couldent find any decant pics of the same motor with a closed vs open deck kthanks subbie)
i hope you not running the factory oil cooler/filter block on that!!!!!!
have fun keeping it coool.
ie: 2 seperate 25 row serk coolers in -10 cant do it, it all bypasses inside the factory oil filter block, 4 valves 2 for the filter 2 for the coolant/oil cooler
in mine anyway, perhaps im special
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
