Hi all,
I installed my SAFC, but ran into some problem, as described,
Idling is weird, and when i accelerate, its feels like its hesistate, and can NEVER rev pass 2500RPM.
smoke in the exhaust alot as well.
I did ECU diagnose, and got code 12: AFM circuit
I am not sure if i blown the afm circuit or the inside the ECU,
anyone know how can i get it fix?
or any place in Sydney? i can take them to?
thanks heaps!
darrien
https://www.sau.com.au/forums/topic/111354-installed-safc-something-wrong/
Double check all the wiring to make sure you've done it correctly... failing that make sure the "setup" process was done right - I remember having this problem as well, all it was was a wrong setting whilst doing the setup stuff.
If it still doesn't go good after, send me a PM - you can bring it down to our workshop - we've gone through many SAFC installs now :D
i fink i will bring it down,
because at the moment, i cant think of what i did wrong!
i need another opinion! i read the instruction very carefully and done it carefully!
the only thing i can think off is,
I the turtorial section: they have ECU pin layout different from the Apexi ecu layout.
They ground wire in the turtorial is PIN 60, where as the ground in the APEXI website is pin 26 (next to air flow signal).
Initialy i wire it to the wire #60, but then i change it to wire #26. but problem still there!
Oh,
i already did posted it on the Skyline relate forum. In similar topic.
I took raz0r$harP advice.
it just when i conect the wire, i pulled them bit hard, and the pin that connect the ecu harness to the ecu pin loose, caused no conections.
Edited by RBFIRE
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
