Hey guys just a few odds and ends for sale
Located in MELB
I can send parts at buyers expense
Parts can be picked up
I'd prefer bigger parts buyer organise freight and I just drop it off somewhere, but can come to agreement with potential buyers.
Now to the parts!
All R33 GTS-t parts...
Some have pics others dont
I'll list some stuff off top of my head without pics and pics can be arranged later
1x Fuel tank and what im told was GTR pump in it
(anyway of finding out i will look for anyone keen?)
$120 lot
1x Silver Passenger Side Front Gaurd 2 tiny dents - $60
1x White Drivers Side Gaurd - Great nic - $100
2x Space Saver Rims With Tires (never used) $25 each
Rear Seats - $50
Rear Diff Cradle - $100
1x 3inch Aftermarket Exhaust (brand name unknown but good exhaust) - $250
2x Starter Motors - $100 each
Wiper Motor Front And Rear - $50 each
Wipers - $20 pair
Various Interior Plastic Parts (msg me for specific part needed with offer)
I'll go thru whatever else I have this weekend, Ill try get it listed...
Those who are interested, Just PM me and I'll get back to u asap
Thanks
https://www.sau.com.au/forums/topic/111874-r33-skyline-parts-4sale/
I've sourced up some pics of the exhaust for those that were requesting, the type is unknown, but it has "JASMA" printed on the cannon rear muffler.
Any other enquiries, feel free to let me know.
Cheers guys.
Edited by HEDAKE
More itty bitty shitty parts for listing:
Interior handles - $10each
Dash Cluster Surround Plastic - $25
Misc Vents - $25lot
Complete Glove Box - $40
Interior Fuse Box Cover $20
Interior Lights - $15each
Clock - $20
Boot Release Mechanism with wiring - $30
Orig Nissan Fuel Cap - $20
Hazard Light Dual Button Thingy-Ma-Bob - $20
2x Horns - $10each
Under Sterring Wheel Plastic - $30
Silver Fuel Cap - $20
Over Flow Bottle - $20
Climate Control Unit - $70
PICS CAN BE SEEN HERE
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
