hi guys... noticed this yesterday when slowing from abt 80-0 along hoddle st in melb... there was waht sounds like the usual 'low pad' metal on metal scraping sound comin ffrom my front left brake.. had a look this morning and the pad seems like it has heaps of meat still left, so i pulled the wheel off and took a closer look.. see the photos.. the pad is rubbing on the hub...
is this supposed to be happenin or is somethin loose
https://www.sau.com.au/forums/topic/112144-brake-pad-rubbing/
No it shouldn't be happening. The pad should clear as in the photo below. Best get it sorted before there is another Hoddle Street massacre...
ok.. think ive nutted it out by looking at it... that pad was on the outside of the disc, when it should be the inside pad... whoever did the pads b4 i bought the car must have had it in the wrong way... does that look/seem right...
ive swapped them round and all seems good.. wouldnt mind confirmation tho..
holy crap you mean the pad side was facing away from the disc and the backing plate was rubbing on the disk?
I can't really tell from the photo....but if thats what happened you were in a death trap. Take it back to the dealer and get brand new discs and pads and jump up and down a bit
no, the pads were just around the wrong way , with the outside pad being on the inside of the disc and vice-versa..
makes me wonder abt other work that may have been done on the car with such errors... touch wood...
How would you of got the pins to hold the pad in there then?
One pad has a wear indicator on it and the other hasn't by changing them around you have stopped it from rubbing.AT least you found the problem quickly. Inside of disc face there is nothing for it to foul on but outside face of disc it rubs on the rotor hub as you can see in your picture.The pads are only held in by 2 pins so they can be put in either way.
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
