dont forget to take into account
-torque
-gear ratios
-driver skill
It's not just power that makes all the difference. I dont know the specs on supra's but I know toyota makes some good powerful motors. Common sense though tells me an R33 gtst will rip an NA supra (if both drivers of equal skill).
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-188312
Originally posted by ed
ask sura, he has a NA supra.
EDIT: NA supra's would be doing 14's down the 1/4. stock.
I am quite a heavy guy so i must weigh my car down even more, but i can not see myself doing quarter in 14s. I haven't raced a stock r33 yet, but i don't mind trying. Even as owner, i doubt i can really do that well against it. Don't get me wrong, its not slow.. but i think compared to most of the cars i go out with, the power output is too little. Fortunately its still be best looking car in all the DRD's. :) :shake:
As a comparison tho, i have heard it beat stock 180sx and r32 with exhaust and air pod. I beat a charade too!!! ( i dunno why he tried to race me) hmm... i dun have many other kill stories ..hhehe
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-188344
Originally posted by BigDatto
I drove a non-turbo MK IV Supra 'bout a month ago, at an import dealer in Brisbane. My Proton GTi would easily whoop it's ass. felt very solid, but ultimately it was a SLUG. Still a P~ssy magnet tho'.
just my 2 zloti.
can't argue with that one ... most girls don't even know what a turbo is ... i dont' even think a gtr can compare to a supra in a girls mind ... beats us in that department :D
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-188421
Originally posted by hippy
can't argue with that one ... most girls don't even know what a turbo is ... i dont' even think a gtr can compare to a supra in a girls mind ... beats us in that department  :)
I drive Supra for 6 months now
i still get no Wimmin from that car...
What am i doing wrong Ed???:D :goddam:
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-188426
I saw a NA supra (new shape) running the quarter up her in NT. He was so ashamed he actually pulled the number plates of his car before he ran 16.2s over the quarter, either he was useless or the NA supra is all show and no go. I heard that later on in the evening some mates pulled up next to him in a 100 series turbo diesel land cruiser wanting to race him at a set of lights but he didnt want to :P
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-190218
If Im not mistaken, NA supras run the 100 in high 6's and the quarter in about 15sec. Meaning the're around about on par with stock r32 gts-t's and a bit quicker than stock NA r33's (0-100 in low 7's/ mid 15's quarter mile).
I saw the stats in one of the import performance mags a little while back, comparing NA supras with r33 GTS's.
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-190622
HPI tested NA supra with NA R33 Skyline and Supra came out on top. Probably cause the supra has 500cc more capacity.
Comparing NA Supra to R33 GTS25t ain't exactly a fair match up. Supra's got more displacement, but a turbo will more than make up for the missing 500cc's in the R33.
On top of that modifying scope in the Supra is a little narrow.
https://www.sau.com.au/forums/topic/11221-na-supras/#findComment-191020
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
