hi stupid question but will they fit onto standard turbos from a 96 rx-7? as a mates looking 4 new actuators.....
don't know...do some research and get back to me....ok
Im not sure if this is a exact HKS actuator but this will give people a better idea of what they look like fitted stock highflow
Cheers Lee....that looks disgusting....people they look nothing like the abomination displayed here by lbfalcon (that was not even HKS). Mine are in great condition and working order.
I'm willing to go halves; my new turbo "looses" boost at the end of the RPM scale - been told one of these will fix it up!
Correct...the factory wastegate is being forced open by lack of spring pressure...these fix that.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
