hey all,
ive tried serach any date without luck, maybe im jus a dumbas*
was just wondering if anybody has bought a Greddy 60mm pillar gauge holder.
the 60mm apexi gauge i want to install just won't fit.
From my understanding, fitting shouldnt be a problem since its precut. Now ive measured the hole and its about 59mm in diametre. im just wondering if anyways else has installed one, and how they went about fitting in the gauges.
Did you just force them in? or is cutting required? just wanna make sure before i wreck an expensive bit of plastic.
https://www.sau.com.au/forums/topic/112421-fitting-60mm-gauge-in-greddy-panel/
I've got one of those holders and a 60mm Apexi guage (EL2, mechanical) and I didn't have any problems getting the guage to fit in. In fact I can pull the guage out of the holder very easily! The way I've installed it, the silver outer part of the guage sticks out of the holder if you can imagine. The rest goes inside.
I've got the Greddy dual pillar pod and my Defis wouldn't fit in there. It's made of plastic so I just got some sandpaper and ran it over the inside edges a few times until it fit.
Don't go cutting it. Sand it down bit by bit - testing it along the way until you get a snug fit :)
hey guys,
thanks for all the replies.
yea i was thinkin about that sanding method. was just hoping theres not much to sand, since the holes are very close to the edges as it is.
And yea, i have a feeling mine might be abit of a bIt^ch to fit as well, becos when i put it against the pillar, the top part of it doesn't seem to align flush and blend in nicely.
maybe ive just been unlucky and receieved a dodgy one, but just makes u think paying extra for a Greddy (precut and match car model) one, u'd expect it not be sh^t.
anyways i'll get it in one of the these days and post up a pic and let u know if particular dramas. Thanks for the tips guys.
Edited by mle808
maybe ive just been unlucky and receieved a dodgy one...
mine was like that too at the top edge...my solution was to get a heat gun and make it soft enough so you can mould it better to the pillar (you could prolly also do the same with a hair dryer - it would just take a little longer). I also smoothed the sharp-angled edge so it followed the contours a little better.
don't be afraid to mod the mods :)
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
