oh okay, Well its pinging at the start when i take off whilst still cold, on boost etc and when warms up and giving it too it runs sweet just at the first stage ie, engine temp 20 odd deg and air temp 8 deg in the cold mornings,
so you think its air temp comp could someone pls verify
how about engine temp comp?
i dunno
I think you need to adjust the air temperature compensation table (via laptop).
Frankly, I don't worry about it running lean "off-boost" - only when I get it into the upper load bands.
doesnt the engine temp correction take care of that, so it wont ping when cold ?
Yeah it will if its setup properly, can be hard for the tuner if you dont leave the car with them so they can tune it at those temps so thats where a bit of guess work might come into it. I idle my car till i see 55-60 degrees water temp before i drive it and dont boot it till its at operating temp, but each to their own i guess.
thanks for the help those who offered.
its all sorted ,finally got a laptop, and just richened up then engine temp compensation a little bit up to the 40deg mark runs a little but rich now but better than lean, i suppose i just moniter it over the next few days but last two since have been a-ok, driving away at 12degrees engine temp
and where do i get this software? but i am pretty happy with my overall tune. lucky had a good tuner, but there is always everyday improvments to be made wouldnt mind saving some petrol
New software about to be released that will make these easy ECUs to setup and the base MAP list is quite good now.
i dunno
Is the wolf controling the idle speed via IAC valve? Chances are its pinging cold as there will be about 4 -8 degress more timing on top of the main table at around 30 deg ECT.
nah i got it sorted with the slight changes i made, i am 99.% sure hasnt done it since anyways
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
