ive been qouted 550 dollars for a bare metal respray for my bonnet. its the last thing i want to get done on my car as my bonnet has some stone chips on it and a key mark on the front of it. any tips for someone that has never had anything sprayed before. any reccommendations of spraypainters. cars going on to a r31 dyno day tommorrow with the boost up :) :) more and then off to respray the bonnet :) then its finished till something brakes:)
https://www.sau.com.au/forums/topic/112696-bonnet-respray/
Tim, go see Lanley Motor Bodies in St Mary's, just behind Keith Bowden Electrcial (2nd Street on Right, building on Left).
Ask for Ken and tell him I sent you there. He has done work on both mine and Dad's cars (not the GT's though) but his work is top notch :) Known him for about 10 years now, tends to look after us
https://www.sau.com.au/forums/topic/112696-bonnet-respray/#findComment-2078581
thanks lee ill try them this monday
S & N Crash Repairs. Ask for Sam. I had my front bumper sprayed for AUD 150. Pretty good job. Nice bloke too! Old enough that you can be sure that he won't be boosting your car when you left your car there over night!
thats the one thing im worried about some guy taking it out while its cold and redlining it :
https://www.sau.com.au/forums/topic/112696-bonnet-respray/#findComment-2080049
That sounds a bit expensive for a bonnet, being on of the easiest panels to paint
If you havent already got this done, try GFC Automotive Refinishing (He's the agent for Colour House, aka. Meguires) and absolutely ace work!
https://www.sau.com.au/forums/topic/112696-bonnet-respray/#findComment-2088584
thanks for all the input guys. i got my car booked into benjamins on tuesday comin up... top bloke and hotwire its ken's brother so he goes cheaper than ken. $400 bucks is what im looking at for bare metal respray :D ive also already seen examples of his work on my mates gts2 which has been resprayed by both ken and craig. on seperate ocassions.
https://www.sau.com.au/forums/topic/112696-bonnet-respray/#findComment-2091534
i got a quote it was at aplace in blackwood that just qoutes adjacent mv autos then sends them off to lonsdale to get done.
Find out who does it in Lonsdale as there is a VERY VERY bad spray painting mob on O'Sullivans Beach rd Lonsdale. A tip.. They are a big blue company. :D Blue tow trucks, blue building.
I had big drama's with them and still the paint isn't that crash hot, no runs any more but not a good quality paint finish, quite depressing.
Another friend of mine also had troubles with paint runs from the same place 6 months prior to having my car done, unfortunately I didn't know this at the time.
EDIT: That will teach me for not reading the whole thread. :bunny:
https://www.sau.com.au/forums/topic/112696-bonnet-respray/#findComment-2095517
Find out who does it in Lonsdale as there is a VERY VERY bad spray painting mob on O'Sullivans Beach rd Lonsdale. A tip.. They are a big blue company. :) Blue tow trucks, blue building.
EDIT: That will teach me for not reading the whole thread. :D
Try across the road at Quality Crash they do good spray jobs and if you show them you are in the know won't charge through the roof either. Had work on my car done there!
https://www.sau.com.au/forums/topic/112696-bonnet-respray/#findComment-2109911
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
