Hi-flow cat 3" $250 -300. I have no cat, which is better than gutting it, an empty cat still creates turbulance, which is bad. You can buy a cat remover, which comes with tags to add a cat exterior over a straight bit of pipe.
See'ya:burnout:
See'ya:burnout:
Is this legal?
T.
Any removal of a cat is ilegal!(These cat remover pipes are for competition use only)
Also it's $250-$300 + fitting cause they aren't bolt in items!!
Carsound is a good brand of high flow cats!!, and they are true high flow cats!(have fitted hundreds of the them, mostly to Holden's and Ford's though but have done a few Skyline's, Supra's , Soarer's and a few other imports!
MEGA
And for all those who think that the term "high flow cat" is an oxy-moron.
Here is some tests done on a LS-1 chev(sorry couldn't find a Skyline one) with modifying the standard cats and comparing them to high flow ones on the flow bench.
Here is the link:
http://www.installuniversity.com/install_u...on11.122001.htm
Also I personaly couldn't run my car without a catalytic converter as the power increase would only be approx 3%, and even less compared to a high flow catalytic converter, this also would make any car a rolling defect notice and make it even more destructive to the atmosphere!
MEGA
I had a high-flow cat in mine, and since it's removal have had no issues and the car is producing more power. I had to remove it to run rotational idle and anti-lag, I don't recommend this approach to most people, just those after serious power. And yes there are legal and enviromental rammifications.
See'ya:burnout:
i just bought a 3 inch catco cat which should be hear next week.
cost me $170 brand new. i just got to get the flanges put on.
its a stainless steal one too. will let u know how it is. but i will not be able to tell the difference as it will be on the car from the very start once it gets started up.
silyRB
Guest sirmx6
Bit confused on the difference between gutting a cat and fitting a 3-inch hi flow cat.
What is the advantage / disadvantage of doing either ??
When you say gutting the cat, does that mean the standard cat or an aftermarket one ??
Reason i ask is that i have a 3-inch dump into a 2.5 inch cat and then 3 inch piping from the cat back.
Which one is going to work better for me - gutting the 2.5inch cat or fitting a 3inch high flow ??
i think by gutting he is refering to just having a straight through pipe with the cat casing on the outside to keep it looking leagal
i think u should go the 3" pipe, i always like doing something properly from the start unless its way out of reach. if u have to pay that little bit extra then do it otherwise u will pay for a 2.5, then want a 3" and so your paying more than u originally would of
Originally posted by BATMBL
Hey guys,
I know the guy who produces the parts for CATCO (Jappsport uses their cats for compliance and he comes by to sell them to us), so I can get any1 thats interested, a CATCO 3 INCH HI-FLOW CAT with the flanges for $160. You can come and pick it up from where I work in liverpool, sydney (Jappsport) or i can ship it to you interstate for a little extra.
I can also get 3 inch dump+front pipes (one piece, easy to bolt on) for r33 and r32 for $260.
If you want a 3 inch stainless steel pipe, its $100 extra.
I can also supply you with front+dump pipes for 180sx.
These I get from the same person that produces the cats for CATCO.
cheers
BATMBL: How about the above parts for an R34?
Can you get the CATCO cat and dump / font pipes? And are the prices similar?
I already have a 3.5 inch cat-back exhaust. I am assuming this stuff would complete my exhaust system?
Thanks!
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
