Vital info for upcoming World Cup.
The offside rule explained (for girls).
You're in a shoe shop, second in the queue for the till.
Behind the shop assistant on the till is a pair of shoes which you have seen and which you must have. The female shopper in front of you has seen them also and is eyeing them with desire. Both of you have forgotten your purses.
It would be totally rude to push in front of the first woman if you had no money to pay for the shoes. The shop assistant remains at the till waiting.
Your friend is trying on another pair of shoes at the back of the shop and sees your dilemma. She prepares to throw her purse to you.
If she does so, you can catch the purse, then walk round the other shopper and buy the shoes.
At a pinch she could throw the purse ahead of the other shopper and, *whilst it is in flight* you could nip around the other shopper, catch the purse and buy the shoes.
Always remembering that until the purse had *actually been
thrown* it would be plain wrong to be forward of the other shopper.
  • Replies 45
The LAPD, The FBI, and the CIA are all trying to prove that they are the best at apprehending criminals.
The President decides to give them a test. He releases a rabbit into a forest and has each of them try to catch it.
The CIA goes in. They place animal informants throughout the forest. They question all plant and mineral witnesses. After three months of extensive investigations they conclude that rabbits do not exist.
Then the FBI goes in. After two weeks with no leads they burn the forest, killing everything in it, including the rabbit, and they make no apologies. The rabbit had it coming.
Then the LAPD goes in. They come out two hours later with a badly beaten bear. The bear is yelling: "Okay! Okay! I'm a rabbit! I'm a rabbit!"
<stretches>
Gary Glitter & Michael Jackson are sitting on a park bench when a 8 year old girl walks past with her family. Gary leans over to Michael & says, "Shit, she must have been good back in her day yeah?"
<legs it>
A woman was having a shower and slipped over on the bathroom
floor. Instead of slipping over forwards or backwards, she slipped over,
did the splits and suctioned herself to the floor.
She yelled out for her husband Jacko.
"Jacko! Jacko!" she yelled.
Jacko came running in.
"Jacko, I've bloody suctioned myself to the floor" she said.
"Strewth!" Jacko said and tried to pull her up.
"You're just too heavy girl. I'll go across the road and get Bluey"(his
mate).
They came back and they both tried to pull her up.
"No way. We can't do it" Bluey said "Lets try Plan C"
"Plan C?" exclaimed Jacko. "What's that"?
"I'll go home and get my hammer and chisel and we'll break the tiles
under her"
"Spot on" Jacko said. "While your doing that, I'll stay here and play
with her t!ts"
"Play with her t!ts"? Bluey said, "Why the hell would you want to do
that"?
Jacko replied "Well, I reckon if I can get her wet enough, we can slide
her into the kitchen where the tiles aren't so expensive"
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
