  • Replies 40
$200 for a new light assy?????Please tell me where you can get a new light for an R34 for that price..... expensive???Wtf can you get for $80 these days???No wonder this country is full of shit products with people complaining about parting with such a small amount of money.....
I was talking R33, i didn't know this was an R34 only thread... jeez.. not everybody has massive amounts of money to throw away on paying somebody else to do everything when it can be done yourself most likely.
Originally posted by CR34TION
nah mate.... i won't be doing that drive to ballarat for a while...
does that mean i have a twin out there???
so far i'm the only one i know of that has a silver gtt with bronze wheels.. but i then again i don't get out much..haha
yeah, you just get your girlfriend to drive you CR34TION you tiearse on petroL! :P
There are a couple of silver 34's around...I saw one near chapel last week HOTR34 but dont know if the wheels were gold or not...had the large nismo wing at the back though...
nah.. u will love them.. you will also get lots of attention.
i just have to seal mine up at the top i think... maybe don't even need to remove the whole thing.
Do I want this attention though? Usually "attention" includes the boys in blue ?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
