Hi all. I have a mate who has just got a set of new model (square) headlights from Kudos Motorsport after having a bit of a hit.
They lights came as a package for front and rears but he wants to swap the fronts for the projector headlights.
Soooo if anyone wishes to swap their projectors for the new model square headlights you can contact Daniel on 0422 174 560 or leave your interest here. Lights are in perfect condition and have not as yet been fitted to the car.
Thanks.
https://www.sau.com.au/forums/topic/113793-swap-new-for-old-style-headlights/
yea i think this is the style. if he want to jsut clean swap for the older style ones get him to give me a call on 0429022481 and ill do it.
Located in Vic. Why dont you give him a call since he is selling them and the number is listed.
Thanks.
