hey all,
next week im going to look at a series 2 r33 gt-st thats for sale and i was wondering if you could give me some pointers as to what to look out for when i check out the car.
Car has done 80K's and looks very clean.
mods are :
blitz turbo timer
blitz pod
turbo smart bov
defi black face boost guage
tein adjustable coilovers and tie down rods
enkei 17" rims
GT-R wing
the asking price is 20.5k, does that sound reasonable or should i bargain abit? The colour is pear white and the car is a manual
ive fallen out of the import loop for the last 2 years but finally im on my way to owning an r33.
well, if theres anything i should look out for me let know.
also, if there is anyone on the goldcoast who is willng or able to help a newbie, would it be possible to come check out the car aswell? As this is my first turbo car i really dont want to get stung with a car that looks good but has been thrashed to death.
cheers
https://www.sau.com.au/forums/topic/113798-looking-to-buy-my-first-r-33-gt-st/
i think u shud bargain abit.. i sold my '96 r33 for 17k flat. had more work done to it and it was in excellent condition, compression was good & body a1. altho i did buy mine for 20k also last year this time. guess u jus gta shop around :) just get it checked out and bring a mechicannly minded friend
all you are doing is focusing on modifications to the car which kinda wont necessarily yeild a good car. you should ideally look for a good clean car that is in awesome condition and if it has a few mods then bonus. the interior state, engine and drivetrain and overall condition are far more important than the mods it has
hey guys thanks for the replies.
yeah i was hoping to find a car the is stock-ish so i can do the mods myself.
i guess all i can do is check the car out and if its clean and in good nick and checks out with the raqc i guess ill be buying it.
cheers
Im looking at buying my first r33 too..
Looked at one the other day - loved it! Got RACQ to look at it - got the full package one (about 200 for the inspection)
And it kinda thew me off...they came back with 2 pages of stuff wrong with it, everything from a blocked window washer nozzle to CV joint on its way out, to a 'illegal interior light' (lol)
Good to know tho.
Ended up not buy that car.
Good $200 investment? Questionable
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
