can you please send some pics of the dints in the guards if they arent too bad i will give you 150 for the boot
and both front guards
please let me know asap cause i have some others lined up.
thanks
$150 for 2 gaurds and a boot? your fkn DREAMING! go call a wreckers n see what price they quote u!!
  • 1 month later...
i am afraid i am in the same boat, i am waiting for a master cylinder and booster, which was paid for on the 19/04/06, he apparently posted it about a week later from what i can gather... but it hasn't turned up on this end.. he promised to chase it up a little while ago and i am yet to receive a response.
I don't want to start jumping to conclusions, as it sounds like he is having a bit of a tough time lately. so all i can say is that i am yet to receive my stuff almost 2 months on (and i havn't had an issue with Australian post before)
Hi Guys,
just letting you all know that my parts are apparently on the way, i woke up this morning to find a package with a set of wiper arms in them.. after a bit of chasing (there was no sender listed on it), i found that they had obviosuly been sent to me instead of my Master cyl and booster..
so somebody here has my parts and i have yours :laugh: the guy that sent them is organising to get them redirected for us. but whoever it is, please let me know.
Kent
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
