Guest KILLER-T
I need help from someone that is clued up on Power fc's.My car has a real bad hunting problem at idel it has done it since i put the power fc in my car and its giving me the shits.I had a read of the FC manual and it has a idle self learn mode it goes into after the ecu is first installed can i get the ecu back into this mode by unpluging and then pluging it back in.It has to be something with the ecu because i put a new afm in and it still does it and if i plug a stock ecu in and it idels fine :P
https://www.sau.com.au/forums/topic/11391-power-fc-idle/
Hi Killer, in the PFC the AC, power steer and electrical load are all settable. I have seen a couple where the AC on is set lower than AC off. Check them on the Commander in the Settings menu.
For other tests, select the set up menu on the Commander and monitor in real time the outputs from the sensors. While the engine is surging you should see illogical changes in one (or more) of the sensor outputs.
If that all looks OK, then I'd check the low rpm areas on the ignition and fuel maps. I have seen one with a rogue number (very rich) in the fuel map and this made the engine idle unsmoothly whenever it was at that particular load point.
Hope that helps.
https://www.sau.com.au/forums/topic/11391-power-fc-idle/#findComment-193060
Thanks for the input but if the powerFC is re-initialised then all this should be default right?
When you say you've seen these thigns surely it must be on preset or second hand PFCs?
https://www.sau.com.au/forums/topic/11391-power-fc-idle/#findComment-193119
does it hunt when you start up, or only when coming back from revs - eg when slowing down. I had this problem - two things caused it. At idle, it was vacuum leaks - really small ones, check your hose clamps and visually check all hoses that come off the plenum - I found many, clamps that were a bit loose and old deteriorating hoses, replaced them and all is good. I think the power fc may be a bit sensitive.
Secondly I had trouble coming back from revs. This was to do with the idle being incorrectly set and the accelleration fuel cut recovery rpm being incorrectly set.
These settings worked on mine (sorted the problem out)
Idle ac off : 700
Idle ac on: 710
Decel...ac off: 1100
Decel...ac on: 1300
Just a couple of other things to check.
https://www.sau.com.au/forums/topic/11391-power-fc-idle/#findComment-193135
Guest KILLER-T
it must be if its sitting there @ idle and i move the butterfly just a mil or two it clicks and when i return it back to idle it clicks again.The clicking noise is comming from the left hand side of the engine just infront of the injectors.It has a plug with a brownish end on it i will take a pic and show u that might be the easy way:uh-huh:
https://www.sau.com.au/forums/topic/11391-power-fc-idle/#findComment-193211
The click you're hearing is indeed the VCT solenoid (on @ 1400rpm - off @ 4500rpm from memory?) VCT on the RB25DET is for low/mid range torque. The solenoid & plug is as you described it, mounted behind the inlet cam gear on the LHS of the motor.
https://www.sau.com.au/forums/topic/11391-power-fc-idle/#findComment-193241
OK, I had a look and the thing with the redish connector is the Variable cam timing pickup (I think). If your car is idleing and you give it some throttle have your hand on this to make sure that is where the noise is coming from.
Does it appear to be loose?
I've never heard of one of these breaking before, but it might be best to take it to a tuner to ask if it's safe to remove and have a look at it.
See'ya:burnout:
https://www.sau.com.au/forums/topic/11391-power-fc-idle/#findComment-193270
Trust me here guys the item your talking about IS the VCT solenoid :P If you free rev' the motor in neutral @ 1400rpm you'll hear it turn on, "CLICK", then as the rev's drop below 1400rpm you'll hear it "CLICK" again as it turns off. I've had a small test globe connected to the VCT plug & watched the light go on & off to see what it was doing.
https://www.sau.com.au/forums/topic/11391-power-fc-idle/#findComment-193273
Guest KILLER-T
ok so we know its the vct kickin in at 1400rpm like it should so its not that any thing else i have a few odd numbers on my commander eg. this is my inj map
99 / 99 / 99 / 101 / 102 / 103 / 101 / 100 / 100 / 101 /
103 / 101 / 100 / 115 / 119 / 125 / 125 / 125 / 125 / 125 /
line 2
99 / 98 / 90 / 90 / 90 / 90 / 90 / 90 / 90 / 90 /
90/ 90 / 90 / 90 / 90 / 90 / 90 / 90 / 90 / 90
and it repeats this untill line 8 and then the numbers start increasing with every new line
i cant undersand why the numbers should be so high on the first line :confused:
https://www.sau.com.au/forums/topic/11391-power-fc-idle/#findComment-193359
Originally posted by GTS-t VSPEC
So that is normal then, it's the solenoid making the clicking noise?
Yeah it's reasonably loud, if you aren't listen for anything in particular you'd probably never notice it, if you are then you'll hear it for sure. Next time you start your car bring the rev's up over 1400rpm & then back to idle, you'll hear it.
https://www.sau.com.au/forums/topic/11391-power-fc-idle/#findComment-193420
    • Give it 40psi and send it to the moon
    • I suspect 550s are on the large side for happy operation with a stock/Nistune RB20 ECU. The Hitachi ECU doesn't love short pulse width operation, and the RB20 doesn't need much fuel at idle. Big injectors can be unpleasant. This could be contributing.
    • Yeah, I still don't know why the idle speed control can't catch the falling RPMs. In the Consult logs I see the AAC duty cycle rising, but suddenly it goes lean and the engine stalls. Anyways, the relevance here is the DW 550cc injectors are probably the same. So if OP has similar issues I would be tempted to finger those injectors as problematic for whatever reason vs the ECU failing for some reason.
    • Yeah, sort of blurring two different things together, aren't we? I just meant O2 feedback closed loop. I used to have a 0-1V LCD meter on my dash, wired directly to the O2 sensor signal. So you could easily see what it was doing. Normal running it would flick back and forth nicely. Slow down to an idle and it would keep flicking, as the ECU tried to servo to maintain stoich, but it would slow down as each swing happened until it would stay at one end of the scale. As I said above, the sensor heater is not enough to keep it hot enough when there is also little heat in the exhaust flow. Give it a blip and it would start swinging again, then peter out again. Meanwhile, idle speed control would run just fine, because unrelated.
    • It's not even O2 feedback, it's just simply when the ECU sees the closed TPS signal for whatever reason the idle will start steadily dropping until the engine dies. With the TPS adjusted to not trigger closed TPS it will idle at some ridiculously high RPM and something like 6 degrees of timing. In the absence of getting eyes on it personally and a lot of quality time doing diagnostics I couldn't tell you what the real problem was but it was interesting nonetheless
