Hey guys,
I have an R33 GTS-T 95 with adustable suspension and I assume dapness adjustments .
How do I raise the suspension ?? and adujst the dapness. the car is curently high from the back and realy stiff yet very low and bouncy at the front.
The suspension is Bear Racing (or somthing like that) . My mate told me I need to have C spaners!!! where can I get my hands on a set of these spaners and how do I go about adusting them?
your help would be very much apprecieated, I did do a few searches and found a couple of results however I dont know if its the same process for all coilovers. I also took it to my local suspension place who looked like he had no clue what he was doing and failed to fix the problem after 1 hour of working on the car.
Thanks guys
https://www.sau.com.au/forums/topic/113922-help-please-with-suspension/
Where abouts are you located? There should be a competent workshop nearby.
You need some C spanners...
Have a look at the top of the dampers to see whether there are any adjusters for them. It should be a small slot which you turn with a screw driver.
You may still find that the spring rates are high & that no amount of adjusting the ride height & damping will help.
I'm in Bankstown and Campbeltown. do you know of any around those areas?
I tried to turn it with a screw driver however it just keeps on turning , also if no amount of adjusting would help then why would the front be diffrent than the back ? should it be the same spring rate ? ?
May help if you can post a photo of the top of the damper.
The front & rear spring rates should be different, with the front stiffer than the back. What I was trying to say was that it is not uncommon for Japanese suspension to have very high spring rates which aren't particularly suited to our dodgy roads. If you have such stiff suspension then adjusting the height and/or the dampening probably won't make it ride as well as you would like.
Having said that, if there is a big difference front to rear then either the dampers are adjusted very differently (ie one end soft, the other hard) or you have some busted/worn dampers.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
