hey guys,
i'm new to the site and new to skylines in general. i posted this thread in another section of the site but i only found out about the NA section now.
i've had my Ps for a couple of months now and am looking for a first car.
a family friend of ours is selling a 93 model R33 GTS4 auto non turbo RB25DE. its black, immaculate condition inside and out, not a single scratch on the body. all stock except for the full body kit. its done 80,000 Ks. i know i should be going for a manual but i'm in Vic and have an auto license so i can't drive manual till i'm off my Ps.
he's askin $7,500 for it. does the price sound about right for this car? i have no idea what these cars go for
so any help is greatly appreciated
cheers
https://www.sau.com.au/forums/topic/114136-please-help/
hey guys,
cheers
Sounds like a good deal to me, sucks with your laws how you need to wait till you're off your P's to drive a manual... I did both tests :rofl:
Yea so if you're keen on it get it, your only other option really is to get an even cheaper run about auto until you can get something nicer in a manual.. although for that price it could be considered a run about anyway.
Get it! :rofl:
https://www.sau.com.au/forums/topic/114136-please-help/#findComment-2102368
  • 4 weeks later...
save your money and buy GTR when you have money and skill to drive it.
he's not planing on getting a GTR now, he didnt even mention it? :thumbsup:
For that money you will not find a better car. period. get it before someone else does! cheap motoring. at that price there will be bugger all depreciation. RB25DE is pretty good on fuel too. I average around 9L/100km (manual). Just confirm that he has serviced it and not thrashed it too much!
If you've got your auto license but want a manual car, then do your manual test and then look for a manual car. Don't get an auto if you like driving a manual or you will regret it.
https://www.sau.com.au/forums/topic/114136-please-help/#findComment-2177501
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
