hey ALL.
quick question due to expencive fuel price, my car is alway on boost. do i have to do any thing if i turn my boost conrtoler down to say 4psi, another word mostly on vac. its a light modded car with standard ecu.
thanks
depends, is it a stock turbo? the only way to get it to boost so low would be to disconnect the wastegate actuator, and jam the gate fully open. if left connected, it will boost to a minimum of the wastegate actuator spring rate.
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2105738
r33 s1, stock ecu,stock turbo, 3"inch cat back zost, pod, 11pis boost.the car does move unless i tap it abit harder but then its in boost so i back of. wat i meant to say was. do i have to reset ecu, regap spark plugss or thins like that if i turn boost down really low until petrol price drop a little. i get 400ks with 50-55 litres when i fill up.
Edited by bluer33
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2105799
400km is pretty good though
umm main things to check are the O2 sensor in the exhaust can cause worse economy..
turn the boost back to std 7psi at least.. actuator will allow this..
try a reset on the ecu, also check it for error codes..
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2105838
speaking of resetting the ecu, should you reset it when you turn up your boost?
i turned mine up to 10 psi from 4 ..
Im also getting 450kms per tank with 10 psi.. (which seems to be pretty good) ..
Cheers,
-JD
thats what i usedto get at 50km trips each way to and from work..
on 11 psi.. but a fair bit of cruising
currently getting about 13L/100kms with 294rwkw.. so needs a light load tune redone.
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2105858
Exactly. You get more boost the more you put your foot down. Just keep the revs lower (dont change above 3000rpm), don't warm up the car longer than 30 sec, anticipating red lights, steady and smooth accelerator control etc can all help.
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2105970
lol i love ... untill the fuel prices go down? WE ARE GOING TO GET KILLED BY FUEL PRICES .... it wont go down it will only go up. I payed 1.40 a litre the other day.. when you pay more for a litre of fuel then you do for a litre of milk you know its absolute bullshit. In the few years i have been driving it has gone up almost 60 cents a litre.
Edited by fEkuaR
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2105992
paul,
have noticed that the closed loop on the power FC doesn't seem as good as on the std ecu.
when cruising it
A) doesn't bounce the AFR guage as much
B) only seems to do it when slightly accelerating and sits within stoich while holding the throttle in one spot.
C) when holding the throttle in one spot and its not bouncing, increased load on the engine (say a slight hill) it will start working.
not that its running too bad, im at 300km and 1/3 tank left.
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2106473
paul,
when cruising it
i noticed this too!!!! maybe we should tune the ecu lean and then turn off closed loop mode ?
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2106889
The fuel injection map in the ECU is based on airflow load and RPM.
It has nothing to do with boost pressure
boost affects airflow though...
if you wish to turn boost down, unplug the factory boost solenoid and unplug any other boost controller. that way, it will read about 5psi and will never go into 'high' mode.
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2106982
whilst you are correct, the throttle pedal decides the final factor.
sure if you run 10psi and full throttle it, its going to chew through lots more air. but thats the throttles fault i would expect (ie: the driver) and not turbocharger boost pressure
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2106996
I've noticed that the closed loop on the PowerFC is pretty good. Cruising, accelerating lightly, idling etc, my wideband is always reporting a stoich AFR. I guess it comes down to how close your base map is to stoich! (and the condition of the factory O2 sensor)
Edited by Busky2k
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2108612
closed loop should be bouncing the AFR's from lean to stoich.
i think its like 10 times per minute or something, not just sitting in the stoich area on the guage..
i think the condition affects how responsive the unit is.
Bluer33 - safc would allow you to tune the ECU beter for more economy as the std maps are fairly rich when your giving it to the car..
gaps would only help if they are wrong and not the correct gap.. most people run 0.8 for under 1bar of boost.
dont think a dump would help economy too much, except that it would help with power, so less throttle to do the same as before.. so yes it might, as long as your right foot is in check.
Edited by Craved
https://www.sau.com.au/forums/topic/114308-petrol-price/#findComment-2108663
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
