Item:
hi everyone i have the following forsale from my old GTR
GTR single throttle body conversion kit , custom made , 85mm throttle body is new , manifold , manifold spacers (to replace standard throttle bodies) can use stock 300zx throttle cable , has had much development go in to this .
Price $ 1550
GTR r33 stock injectors good condition
price : $ 50 each
GTR stock coil packs
price : $ 450 the set (6pcs)
GTR rb26 throttle bodies , modified , 48.5mm larger than stock . new condition
price $ 800
R33 GTR dash cluster from V-Spec , 1996 model , perfect condition , 87,000 k's
price $400
GTR custom fuel rail , new condition , NOTICE weld marks on centre return outlet , very cheap !!! for RB26DETT ...
price: $ 275
ARC hood panel , to suit R32 GTR , in new condition , in plastic ... ordered wrong one ...
price : $ 220
GOLD COAST , QLD
Website:
N/A
Item Condition:
GOOD CONDITION
Reason for Selling:
NOT NEEDED OR UPGRADED
Price and Payment Conditions:
PICK UP CASH or C.O.D
Extra Info:
Pictures:
yes
Contact Details:
mark
0410 657 805
Edited by 2jz-180
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
