Hey guys, i after your thoughts on some coilovers for my car (R32 GTST) i want it to handle exceptionaly well on the street cause i probably wont have time to take it to the track. I after maximum grip around corners and in a straight line, i was thinking of going something like tein coilovers but theres so many (HA, HR, N1....) i dont know which ones to choose, so thats were i get confused so thats were i was hopong you guys could help me out??? i was also looking at buying a whiteline suspension kit from Modyourcar.com for $700 + delivery is that a good price, any way this is the combination i was after =
Coilovers???
whitline Suspension Kit
and some 18inch R34 GTR rims
is that a good combination?
any help would be greatly apprieciated, cheers
Luke
https://www.sau.com.au/forums/topic/114371-new-to-suspension/
When you talk about the whiteline kit are you talking swaybars and bushes (handling pack)? It would be worth checking out the group buy section as there is an r32gtst buy on atm i think.
As for coilovers, there are heaps, i wouldn't recommend many of them for street work, as the spring rates are way too high. You are really just going to have to do a lot of reading and gather peoples opinions on the various types available and what sort of driving they do. Also consider the whiteline spring and shock combo if you will only ever see street driving.
The wheels are less important, sure the 34gtr rims are nice but they will be difficult to fit and are bloody expensive to boot, mainly because they look hot!. Some second hand jap lightweight 17's will be your best bet as far as cost/performance goes.
yeah thanks for that ill check the group by out now. im not really worried about ride comfort at the moment i just want my car to be a handling machine :pwned: (but ofcourse i dont wont every bump to shack the shit out of my car and course any damage to it).
thanks guys im gonna buy the whiteline handling pack, but they say to make sure that i get it installed by someone that knows about there products. Does anyone know whos familer with whiteline products in the brisbane area?? well with my choice of coilovers or seperate springs and shocks im still not sure what to do... ive said that id like my car to handle good now i realise thats a pretty broad statement, so ill try and explain it better... i want to take corners pretty quick i enjoy taking my car out to winding roads and getting some speed up + i also like do mountain climbs which consist of lots of tight and narrow corners.... i hope that kinda explained it a little better, thanks again for all your replies.
I'm also new to suspension in Skylines. Wat would be a average price to pay for Coilys? I'm looking for some coilys atm, but the BN kit's going on and going to make it damn hard to reach the right ride height with springs. Unfussed about Coilover brand.
Jason.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
