hey guys,
picked up my r33 which passed all the inspections but i have a problem.
the car randomly stalls at low revs.
i have heard that this can be caused by the bov?
i am running a turbo smart type 2 which is plumbed back.
its really weird, ill boost the car then slow down say, for a corner and when im sitting waiting in neutral the revs will jump up and down then the car will stall.
do i have to adjust my bov? or is somthing else causing this?
sorry for the newb questions.
cheers
https://www.sau.com.au/forums/topic/114500-r33-stalling-at-low-revs/
to reset the factory ecu i have to unplug the battery for a few hours?
as for the stock bov, i dont have it as i bought the car with the turbo smart already installed.
failing that im booking my car into a performance shop nearby which do good work for a full service/tune and hopefully they'll be able to iron out the problem.
well i took the terminal off for a few mins and made sure no power was left in the car and took it for a drive all was fine until.... came back up my drive in 1st, put my foot on the clutch to slow down and bleh.... i lost power steering for half a second and i thought the car had died but the revs kicked up and it kept running.
this is really not cool aye, when i take it to the peformance shop ill get them to check out the afm and all that.
cheers
the car is running fine, when its not idling.
the few times its almost stalled, the battery light has come one when the revs are jumping up and down and the car feels like its going to stall but doesnt.
could it possibly be the idle bypass valve sticking?
if i come up to an intersection in 4th, stop, and put my foot on the clutch the car is fine, but if i stop put it in 1st and roll forward then stop, the car starts having a fit and the revs jump up and down and the car shudders like its going to stall.
any ideas?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
