C210 coupes, one in good condition lots of new suspension and drivetrain parts already fitted. straight body, no damage, good interior
one with front panel damage, requires 2 guards and a grill and bumper to fix, has a 5 month old 253 V8 and celica/supra 5 speed(not sure which) motor has lots of work done to it, spent over 2500 on parts just 5 months ago. Machined by Trapnell Race Engines, ACL Race Series flat top fly cut pistons(60 thou) peened rods, balanced and blueprinted bottom end, New port matched Speedmaster single plane manifold, inlet and exhaust ports tidied, 20thou off heads, new Speedpro billet camshaft, new lifters, new double row timing chain, new w/pump and timing cover,Hi volume sump, double valve springs, block hugger extractors, Alloy rocker covers, Hadfield bellhousing, supra 5speed, Built to run straight LPG, Detailed in black and kermit green.
i really need to move these cars, askin 1500 each. neither would really need much spent at all to be reg'd
reasonable offers will definately be considered.
Please buy them, even one of them would help me out greatly
Jason 0400 039 899
most of you know these cars, but if u need pics, ask.
https://www.sau.com.au/forums/topic/114578-skyline-coupes-must-go-urgently/
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
