Thanks to call from Beau and posted in Spotted I saw my previous Sinsita crashed just up from my place.
This morning around 11am (name removed) came undone on the Condor hieghts circle under full boost. He is understandabley devasted but unharmed. He loved the car as much as I did :D
It looks like it will be a write off and I will post parts and prices in time. It's a great car and has some really trick stuff. Such as a New Garret 2530, Microtech LTX 12 and dash display, CF Bonnet, Veilside front bar, UAS intercooler and custom piping, Genuine Recaro race seats, HKS SS BOV etc...
Damage is front right gaurd, drivers door, roof. The metal bus stop/seat is flattend but luckily no-one was sitting in the shelter.
See Pics
https://www.sau.com.au/forums/topic/114594-lil-sinista-crashed/
So that's where the bus stop went! I was wondering why it was gone when i drove past it last.
That's no good at all. No offence, but i drive up that way every day, i don't see how an accident like that can happen if the driver was being sensible. But hey, i'm no angel myself. At least the guy is ok, seems like it could have been a lot worse.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
