Hi guys, I'm a proud new owner of a 96' r33 gts-t. Just got it a few days ago and its been driving great! One thing though, I've been experiencing times where the HICAS light would come on after driving for some time.
Tried to do a search to gain more information in the forums but somehow no one has explained if it was a big issue to have that light or not. Could anyone help me with this? Should I get it repaired? If so, how much would it cost? Thanks.
Edited by blu3chip
https://www.sau.com.au/forums/topic/114704-hicas-light/
could be a number of things wrong with it...have you checked your power steering fluid? have you got a smaller steering wheel?
No, I haven't done anything to my car. It only seems to happen after I drive at high speeds or for some time.
Edited by blu3chip
https://www.sau.com.au/forums/topic/114704-hicas-light/#findComment-2113298
I have had exactly the same problem.
I bought a S2 R33 GTST about 3 weeks ago with 57k on the clock. Everything is perfect except that the HICAS warning light comes on after driving for a period of time. I logged the time from starting the car and kms until the HICAS light comes on and found that it was dependant on distance travelled only, with the light consistently coming on after exactly 10 kms whether driving on freeway or twisty roads below and above 80km/hr. Time travelled varied in each case and had no effect on whether the light would come on or not.
To clarify, when the HICAS light is on, it means that the system is disabled and 'normal' steering (front wheels only) is in operation. I have also attempted to run the diagnostic procedure in the skyline book from this website but have not even been able to get it into diagnostic mode (ie car operates as normal, no flashing error codes from HICAS light). I have also taken the car back to the dealer twice and they cannot find any problems, also having the HICAS control module replaced has not fixed the problem.
If anyone can shed any light on specifically getting the Diagnostic mode to work that would be good.
https://www.sau.com.au/forums/topic/114704-hicas-light/#findComment-2120119
Do the search. We don't like regurgitating this every 3 months.
I have used the search heaps, sometimes you can get some good results and sometimes not. I did find one possible solution regarding aligning the steering wheel and checking the steering angle sensor which I will try. I thought I would still post anyway seeing as though most of the time the problem isn't clearly defined (ie what causes light to come on, under what conditions and is it consistent), also the answer nearly always is to just get rid of 4ws, but I would prefer to keep it working as I don't race or drift.
Edited by R.C
https://www.sau.com.au/forums/topic/114704-hicas-light/#findComment-2122499
Well there is very detailed information you both have offered here so we have to play the guessing game again!! There are just a few hints that you could offer like:
aftermarket steering wheel or not (as HICAS uses a special boss to turn the steering position sensor)
is the steering wheel aligned centrally when you drive
is there the same number of turns from centre to lock on each side
HICAS also warns of low PS fluid in R33
Just anything odd or non standard to do with steering.
If all else fails either:
a) leave it and hope it doesn't make the rear act up, or
b) lock it, but don't ask. I have none left until later in the year.
https://www.sau.com.au/forums/topic/114704-hicas-light/#findComment-2122592
Thanks for the info.
In my case all steering components are standard. Have checked the P.S fluid and all electrical connectors and steering is straight when on flat level road. Also my car has a 3 year 3rd party warranty and 3 month dealership warranty so I am not paying for anything hence why I am trying to get it fixed. The only problem is I don't have that much confidence in the mechanic who is looking at it (having taken it back twiced to no avail) so I am trying to help find the cause myself.
Appreciate your input.
https://www.sau.com.au/forums/topic/114704-hicas-light/#findComment-2123578
R.C, we seem to be having the exact same problem. My HICAS light comes on after 10-15km's of driving continuously though I've not done/changed anything to try to fix it. My problem however, should be able to be fixed with a change of the PS fluid as mine is filthy now. Do let me know if you've managed to verify the problem though as it seems like we're on the same path. Cheers.
https://www.sau.com.au/forums/topic/114704-hicas-light/#findComment-2128405
Seems like this is a very common problem for a lot of people!
I did take the car back to the dealer on the weekend and got the mechanic to look at it while I was there. We took the steering wheel apart and looked at the s.w angle sensor and found a couple of faults. The soldering on the circuit board of the sensor had a few dry joints as well as a broken track. These were fixed and put back together only to find the HICAS light still coming on when I drove home. I'm not totally convinced that that wasn't the problem still only because the sensor itself wasn't replaced, something else may have been wrong with it. I still could not get it into diagnostic mode (either could the mechanic) so maybe the sensor is not working at all - ie it does not detect me turning the wheel when trying to enter diagnostic mode?
It's really starting to annoy me now.
https://www.sau.com.au/forums/topic/114704-hicas-light/#findComment-2128767
My friends car is having the same problem.
Its an series 1 R33 and when the hicas light comes on, the steering becomes really heavy, as if the power steering is gone.
The car has recently been in an accident where the rear suspension was damaged as it slid out into a gutter. It has all been fixed, replaced though. Could this just be fluid or something with the Hicas system itself.
No mechanic has so far been able to figure out whats goin on.
Anyone recomend a Mechanic good with skylines in the sydney area?
cheers
Edited by aym23q
https://www.sau.com.au/forums/topic/114704-hicas-light/#findComment-2133018
I had the HICAS light come on when driving the car home along the freeway after about 5 or 10 minutes, and it didn't go off until after I got home and switched off, even after getting off the freeway and into stop-start traffic.
I topped up the power steering fluid which was below the low mark, but the steering was never heavy before or after. I haven't had the problem since, but also I've never travelled as far at highway speeds yet. Also my steering wheel is off-centre but I would think if that's an issue the light would still come on regardless.
https://www.sau.com.au/forums/topic/114704-hicas-light/#findComment-2137350
Update - 1 HICAS problem solved.
After taking my car back to the dealer for the 4th time it looks like I finally have the HICAS problem licked. My initial thought was that it was the steering angle sensor which turned out to be correct. The first clue was that it would not go into diagnostic mode ever, which made me think that it wasn't sensing that the steering beeing moved at all. Anyway, I took it back and told them to replace the sensor (which they attempted to 'fix' last time).
After replacing the sensor and then attempting to enter HICAS diagnostic mode it finally worked, HICAS light flashing signifying no fault, rear wheels entered test sequence turning left and right. The car has been driven on a few trips of more than 10 k's since then with no problem showing up, so it looks like this has fixed it.
LESSON: If your HICAS is playing up (light coming on in dash) and you cannot enter diagnostic mode, one possible cause is faulty steering angle sensor. The light will come on after 10km if it does not sense that the steering wheel has turned.
https://www.sau.com.au/forums/topic/114704-hicas-light/#findComment-2188896
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
