Gday guys just want to start a little bit of a open discussion here, we all know that usually the more octane you run(obviously to a certain limit) the better it is for your car when your dragging/track etc but since you all know the petrol prices have sky rocketed, $1.41 at mobil just before for synergy so i just want to see what people think/experienced when running normal octane petrol not 98 RON? i have been running mobils synergy since i got my car like 2 years ago and it has never noticably misfired or had a problem due to a bad batch of petrol, but since im still at uni and earning jack shit a week was wondering what other people run? I dont go to the track and dont regularly drag so would it be worthwhile staying with 98RON?
https://www.sau.com.au/forums/topic/114916-petrol/
with the stock ecu if you put in crap fuel and nail it, it will pick up detonation and switch to the low octaine ING timing map and back off timing everywhere. it will certianly work, just feel a bit sucky and flatish.
users with aftermarket ecu's can achieve the same goal by basically taking say 5 degrees timing out the of IGN map and it should run medicoreish on crap fuel
https://www.sau.com.au/forums/topic/114916-petrol/#findComment-2115822
I'd rather put my sneakers on than resorting to not putting 98 RON petrol in my vehicle! Thats the last place to cut corners on a budget I say..
Edit - BTW I believe with the ignition retard, your fuel economy will suffer so you wont save much $$ at the end of the day. Maybe enough to pay for a cup of coffee and thats it.
Edited by Busky2k
https://www.sau.com.au/forums/topic/114916-petrol/#findComment-2116064
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
