Hey all,
Just wondering. I dont have a thermostat in my car. I bought it like that and i noticed it as my temp gauge is not working. i called the importer i bought the car off and he also said that the car did not have a thermostat. Seeing that i live in the NT, being very hot here, would anyone think it would be really necessary to have one? its something ive never had to worry with my previous cars so im unsure. Ive heard it should do no harm, especially if you live in a hot environment. Tried searching for this subject in the search icon but no results.
what do you people think?
https://www.sau.com.au/forums/topic/115094-no-thermostat/
The car will just take longer to warm up since the coolant will be cooling the cold block.
Its a common dodgy trick to deal with overheating problems....I would put it back in, get the radiator and cooling system flushed and reconnect the temp sensor....you don't know if there might be a problem if nothing is connected properly and could cook the motor
https://www.sau.com.au/forums/topic/115094-no-thermostat/#findComment-2119445
put it back in asap ( old school dodgy )
thermostats are there also to warm all engine components up at certain times,,if u have a alloy head and cast blok the temperatures will vary and u can do damage seriously,,and from moving to idling the temperature fluctuates too much seriously put it bak in unless your engine is completely cast..
https://www.sau.com.au/forums/topic/115094-no-thermostat/#findComment-2120281
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
