hi peoples im new..
the body kit on the r34 is a bomex style body kit.. im seraching for the same body kit(have any idea where i can get it and the cost?).. and also searching for some fenders and hoods?
It's not Bomex, this is Bomex:
Yeah its definately not a Bomex, like dark said its a gtr kit for a gtt. Try carmate if you want a bomex kit got price on the site so you can esitmate how much itll set you back. I prefer the gtr kit over the bomex makes the front look tough but not overdone.
ive seen a few bodies like this. its also on the HKS RB28 GTR found issue 59 of High performance imports
its an east bear gtt kit, the bonnet looks to be the east bear carbon fibre one which looks like the gtr one except fitting gtt hinges and latch. $1500 from power play.
front bar again is an east bear item which looks like the gtr bumper but designed to blend with gtt's narrower guards.
east bear lower lip is around $500 from power play.
not sure of those side skirts dont think east bear makes them.
Yup definately not a Bomex..I have been looking at this kit as well and found this in Japan:
Was quoted around $1500 landed in OZ! probably still cheaper than the East Bear Kit that powerplay are selling...
is that $1500 landed for just that front bar or a complete kit? im guessing just the front bar but wanted to make sure
OK to clarify a few points. The Front Bar on that car is not an East Bear item. East Bear make the OEM GTR Front Bar. The bar on that car is a NISMO GTR Bar. As you will see in the images below, I have highlighted the areas of the NISMO bar which differentiate it from the OEM one.
OEM GTR Bar
NISMO GTR bar
Now as you will see, the bar on the Black GTT is the same as the NISMO Bar. I don't know how they managed to fit it but I can only imagine that it was either copied or modified to fit. The bonnet is either an East Bear item or a Chinese/Taiwanese one however it isnt clear.
The side skirts also look like factory GTR skirts with the NISMO Under Skirt add on's fitted. There is a GTR rear wing there too so I imagine that someone has spent A LOT of money buying genuine GTR and NISMO GTR parts and modifying them to fit the GTT.
i have the East Bear gtr bar on my GTT - will post pics when i get home. Yes, as tosh pointed out, it's not the one East Bear sells... and looks like the person has squeezed on a genuine Nismo one... guards don't really match too well
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
Ă—
Ă—
