Hey people, got a fair bit of items for sale for those who want it. Ranging from interiour, rims, springs, etc. id like to sell the interiour in one go, not individually.
Interiour: would like to sell all complete without steering wheel $600, with steering wheel $1000
Series 2 front seats, both passenger and drivers
Series 2 rear seats
Rear trims
Glove Box
Centre Light
Full aircon system, including new condensor
Boot lining
SRS airbag steering wheel (very expensive and hard to come by)
Rear seat belts
Full carpet, great condition
Front and rear matts
Springs: Theres to sets, meaning 8 springs so $500 per set
S.W.I.F.T springs (one of japans greatest springs ever hand crafted and highly scrutinized and tested)
front - 13kg/mm
14kg/mm
rear - 15kg/mm
16kg/mm
Rims: $1200 with no extra tyres or $1600 with the extra sets
White (pearl) AVS model6 rims $1200, with good tread currently
Front 16x215x50series (GTR offset)
Rear 16x225x50 series (GTR offset)
Also have 8 or more extra sets of tyres for these rims
please call 0404873163 if u would like anything, or simply pm me
thanks
nathan
https://www.sau.com.au/forums/topic/115200-r33-series-2-gear-for-sale/
^^^^ thanks dude, hahahaha, yeh im in adelaide.........
as to those whove sent me pms, everything is in great condition, i hate having anything looking crap, but id like to sell all my interiour in one go, not in peices........sorry
also got another set of rims for sale,
il post sum pics soon, sorry guys.....been repairing my 33 at the moment, if i havnt been too up to date, still got everything.......internets also screwed up
please re-send all pms if u still want stuff, il get back to u as soon as i can.
sorry again,
the other rims are polished alloy, 17x235 front
17x255 rear (with dish) no major offset, still look nuts.....brand new tyres, bridgestone potenza's
dont have an antenna.....my car was fairly stripped wen i imported it, coz its a track car, then i got interiour for it.....not worrying about antenna, so i dont have that sorry man
the mats are 3 peice, one long one for the rear and 2 fronts...great condition no tears at all or holes...its all up for grabs, sumone please take the stuff coz i dont need it and its only taking up room in my shed which could be used for more important stuff
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
